Installing Hestia should be fine for 4gb or less. Haven’t done a lot of testing as this is currently not the main priority for me.
Also did a test install on Raspbian 10.8 with out any issues make sure you use the 64 bit
ARM support has been merged into the main.
Follow the instructions here:
https://docs.hestiacp.com/development/panel.html#install-hestia-from-packages
You can also use:
./hst_autocompile.sh --all --noinstall --keepbuild main
Please note we currently do not supply any prebuild packages but it might change in the future…
That’s absolutely fantastic!!! Such a good news!
But please add to compile scripts check for enough swap and stop if it’s not present or not enough (or ask user that swap file will be sized up and do this by script).
