Arm64 webmail and IMAP
After installation with this solution for arm64 roundcube not work… =( (On Ubuntu 20.04 arm64)
  1. roundcube on the system(https://domen/webmail/):
[Mon Nov 15 16:37:07.159442 2021] [proxy_fcgi:error] [pid 3888:tid 64592] [client :0] AH01071: Got error 'PHP message: PHP Warning:  Unknown: open_basedir restriction in effect. File(/va
r/lib/roundcube/index.php) is not within the allowed path(s): (/home/admin/.composer:/home/admin/web/cp11122.online/public_html:/home/admin/web/cp11122.online/private:/home/admin/web/cp11122.online/public_shtml:/home/admin/tmp:/tmp:/var/www/html:/bin:/usr/bin:/usr/local/bin:/usr/share:/opt) in Unknown on line 0\nPHP message: PHP Warning:  Unknown: failed to open stream: Operation not permitted in Unknown on line 0\nUnable to open primary script: /var/lib/roundcube/index.php (Permission denied)\n'
Снимок экрана 2021-11-15 195510
  1. Roundcube near (https://domen/2/) install like web app:
    All is good only IMAP module does not work =(
Nov 15 18:39:08 imap([email protected]): Error: Plugin 'imap_sieve' not found from directory /usr/lib/dovecot/modules
Use webmail.domain.com
For custom install I have no idea can it might be configuration issue…
on webmail.domain.com too =(
Nov 15 19:06:32 imap([email protected]): Error: Plugin 'imap_sieve' not found from directory /usr/lib/dovecot/modules
Probably i don’t have Plugin ‘imap_sieve’ =( can i install this for arm64?
apt install dovecot-sieve
Does it works?
Also what is your install string / OS?
There is a bug in both the main branch as the staging branch…
thanks, this helped!
There is still a bug in Hestia main branch use the staging/1.5.0 branch instead for installing
Best thing to do is currently wait until 1.5 release with that we will add the possibilities to install via ATP as you are used to do
Maybe my question not as theme =)
If beta installed, update will be sucess?
Updates via apt are currently hardcoded disabled when we add support to it we will explain how to enable them again
