Assigning ip addres to users thru package
Is there any method(even cli command is ok), to Assign ip address to users thru package they are assigned to?
For example, I have a.a.a.a and b.b.b.b ips. And want to assign like this :
pack1 => a.a.a.a => user1, user2, user3
pack2 => b.b.b.b => user4, user5, user6
Anything available?
We only support dedicated ips so 1 IP per user or a shared ip all users can select the ip
Is it possible to make multiple ips as shared ips?
Or, only single ip as shared and all remaining ips as dedicated ips for individual users?
You can set multiplle ips as shared. But they will be shared allong all the users
You can’t specify:
1.1.1.1 for user1, user2 and user3
1.1.1.2 for user4, user5, and user6
We possible we should look into rewriting the system … one time
Thanks @eris for the clarification.
Seems to be a limitation.
Hopefully, will be resolved in future versions of hestia.
Btw, Great work from all of you devs! and great support too! :heart:
