Greetings.
I have several DNS zones configured as follows:
Zone 1: domain.tld
Zone 2: subdomain.domain.tld
Zone 3: subdomain2.domain.tld
The zones of the subdomains work without problems, however a strange behavior occurs with the main domain. It happens that every certain period of time (indeterminate, sometimes more, sometimes less) the zone of that domain only (domain.tld, for the example) stops working; so I have to delete the zone completely and create it again and, when I do it, it works fine for another period of time.
Obviously it is a tedious process because there are quite a few records that I have to create each time.
I hope you can help me with some idea, thank you very much.
Translated with DeepL Translate: The world's most accurate translator (free version)
------ Original message ------
Saludos.
Tengo configuradas varias zonas DNS de la forma:
Zona 1: domain.tld
Zona 2: subdomain.domain.tld
Zona 3: subdomain2.domain.tld
Las zonas de los subdominios funcionan sin problemas, sin embargo ocurre un comportamiento extraño con el dominio principal. Sucede que cada cierto tiempo (indeterminado, a veces más, a veces menos) deja de funcionar la zona de ese dominio únicamente (domain.tld, para el ejemplo); con lo cual debo eliminar la zona completamente y crearla nuevamente y, al hacerlo, funciona bien por otro tiempo.
Obviamente es un proceso tedioso porque hay bastantes registros que debo crear cada vez.
Espero que me ayuden con alguna idea, muchas gracias.
