Auto update fails to load the panel-URGENT
Suddenly my hestiacp is not working and all the sites inside are not working.
When I hit apt-update I got the following.
Any workaround please urgent.
fix your apt sources, mc3man/trustymedia repo is nothing we ship with hestia (or hetzner ships with its builds).
I have fixed the apt sources and the hestia is now active but can’t able to login to the panel:(
When i put https://my.domain.com:8083
ERR_CONNECTION_REFUSED is coming
Any workaround please.
sudo systemctl status hestia
When try to login to the panel https://mydomain.com:8083
Check your logs in /var/logs/hestia, mostly nginx-error log.
My nginx-error log
try:
chown -R hestiaweb:hestiaweb /usr/local/hestia/data/sessions
And try again, let me know if it works.
No luck the error still persists.
I have fixed the issue by adding hestiaweb user to the sudo group.
One of my clients has the same problem for a few hours now. He can’t access the control panel and none of the client’s sites are working. This is the error and the solution didn’t work.
root@server ~ # systemctl status hestia
Active: failed (Result: exit-code) since Thu 2025-02-06 11:51:40 CET; 5min ago
Process: 413944 ExecStart=/etc/init.d/hestia start (code=exited, status=70)
Tasks: 2 (limit: 77015)
Memory: 31.3M
CGroup: /system.slice/hestia.service
├─1436 nginx: master process /usr/local/hestia/nginx/sbin/hestia-nginx
└─1437 nginx: worker process
Feb 06 11:51:40 server.domain.xyz systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Feb 06 11:51:40 server.domain.xyz systemd[1]: Starting LSB: starts the hestia control panel…
Feb 06 11:51:40 server.domain.xyz hestia[413944]: * Starting hestia-nginx hestia-nginx
Feb 06 11:51:40 server.domain.xyz hestia[413944]: …done.
Feb 06 11:51:40 server.domain.xyz hestia[413944]: * Starting hestia-php hestia-php
Feb 06 11:51:40 server.domain.xyz hestia[413949]: [06-Feb-2025 11:51:40] ERROR: [pool www] cannot get uid for user ‘hestiaweb’
Feb 06 11:51:40 server.domain.xyz hestia[413949]: [06-Feb-2025 11:51:40] ERROR: FPM initialization failed
Feb 06 11:51:40 server.domain.xyz systemd[1]: hestia.service: Control process exited, code=exited, status=70/SOFTWARE
Feb 06 11:51:40 server.domain.xyz systemd[1]: hestia.service: Failed with result ‘exit-code’.
Feb 06 11:51:40 server.domain.xyz systemd[1]: Failed to start LSB: starts the hestia control panel.
root@server ~ # chown -R hestiaweb:hestiaweb /usr/local/hestia/data/sessions
chown: invalid user: ‘hestiaweb:hestiaweb’
I run the command
usermod -a -G dialout hestiaweb
but I get hestiaweb doesn’t exists, however, when I try to add the user using adduser
adduser hestiaweb
then
then
systemctl restart hestia
the hestiacp state is active but admin panel still error 500
     Active: active (running) since Thu 2025-02-06 12:04:39 CET; 8s ago
    Process: 416337 ExecStart=/etc/init.d/hestia start (code=exited, status=0/SUCCESS)
      Tasks: 3 (limit: 77015)
     Memory: 36.4M
             ├─  1436 nginx: master process /usr/local/hestia/nginx/sbin/hestia-nginx
             ├─  1437 nginx: worker process
             └─416342 php-fpm: master process (/usr/local/hestia/php/etc/php-fpm.conf)
Feb 06 12:04:39 server.sabgate.xyz systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Feb 06 12:04:39 server.sabgate.xyz systemd[1]: Starting LSB: starts the hestia control panel...
Feb 06 12:04:39 server.sabgate.xyz hestia[416337]:  * Starting hestia-nginx hestia-nginx
Feb 06 12:04:39 server.sabgate.xyz hestia[416337]:    ...done.
Feb 06 12:04:39 server.sabgate.xyz hestia[416337]:  * Starting hestia-php hestia-php
Feb 06 12:04:39 server.sabgate.xyz systemd[1]: Started LSB: starts the hestia control panel.
I try the updates
apt-get update && apt-get upgrade -y
root@server ~ # apt-get update && apt-get upgrade -y
Hit:1 http://mirror.hetzner.de/ubuntu/packages focal InRelease
Hit:2 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:3 http://de.archive.ubuntu.com/ubuntu focal InRelease
Hit:4 http://mirror.hetzner.de/ubuntu/packages focal-updates InRelease
Hit:5 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:6 http://mirror.hetzner.de/ubuntu/packages focal-backports InRelease
Get:7 https://nginx.org/packages/mainline/ubuntu focal InRelease [3,602 B]
Hit:8 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:9 https://apt.postgresql.org/pub/repos/apt focal-pgdg InRelease
Hit:10 http://mirror.hetzner.de/ubuntu/packages focal-security InRelease
Hit:11 https://apt.hestiacp.com focal InRelease
Get:12 https://dlm.mariadb.com/repo/mariadb-server/10.6/repo/ubuntu focal InRelease [7,767 B]
Hit:13 http://ppa.launchpad.net/ondrej/apache2/ubuntu focal InRelease
Hit:14 http://ppa.launchpad.net/ondrej/php/ubuntu focal InRelease
Err:7 https://nginx.org/packages/mainline/ubuntu focal InRelease
  The following signatures were invalid: EXPKEYSIG ABF5BD827BD9BF62 nginx signing key <[email protected]>
Fetched 7,767 B in 1s (7,826 B/s)
Reading package lists... Done
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://nginx.org/packages/mainline/ubuntu focal InRelease: The following signatures were invalid: EXPKEYSIG ABF5BD827BD9BF62 nginx signing key <[email protected]>
W: Failed to fetch https://nginx.org/packages/mainline/ubuntu/dists/focal/InRelease  The following signatures were invalid: EXPKEYSIG ABF5BD827BD9BF62 nginx signing key <[email protected]>
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  libmagic-mgc libmagic1 libpmem1 python3-ply
Use 'apt autoremove' to remove them.
The following packages have been kept back:
  apache2 apache2-bin apache2-data apache2-utils hestia libgd3 linux-image-generic php-common postgresql postgresql-client-common postgresql-common postgresql-contrib python3-update-manager ubuntu-advantage-tools update-manager-core
0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up hestia-nginx (1.27.3) ...
/var/lib/dpkg/info/hestia-nginx.postinst: line 15: syshealth_adapt_hestia_nginx_listen_ports: command not found
dpkg: error processing package hestia-nginx (--configure):
 installed hestia-nginx package post-installation script subprocess returned error exit status 127
 hestia-nginx
Any ideas?
Fix the repo error you habe there and rerun the update.
root@server ~ # sudo apt install -f
 hestia-nginx
This will solve
chown hestiaweb:hestiaweb /run/hestia-php.sock
Try this
apt update
# Remove the hesita-php hestia-nginx package
apt remove hestia-php hestia-nginx
# Reinstall Hestia  package
apt install hestia --reinstall
# "Reinstall hestia-php / hestia-nginx
apt install hestia-php hestia-nginx
# When Done do a full upgrade
apt upgrade -y
root@server ~ # apt update
Hit:5 https://apt.hestiacp.com focal InRelease
Hit:7 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:8 https://nginx.org/packages/mainline/ubuntu focal InRelease
Hit:9 http://mirror.hetzner.de/ubuntu/packages focal-security InRelease
Hit:10 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:11 https://apt.postgresql.org/pub/repos/apt focal-pgdg InRelease
Fetched 7,767 B in 1s (7,893 B/s)
14 packages can be upgraded. Run 'apt list --upgradable' to see them.
root@server ~ # apt remove hestia-php hestia-nginx
The following packages will be REMOVED:
  hestia-nginx hestia-php
0 upgraded, 0 newly installed, 2 to remove and 14 not upgraded.
Do you want to continue? [Y/n] y
(Reading database ... 51026 files and directories currently installed.)
Removing hestia-php (8.3.16) ...
dpkg: warning: while removing hestia-php, directory '/usr/local/hestia/php/var/log' not empty so not removed
Removing hestia-nginx (1.27.3) ...
dpkg: warning: while removing hestia-nginx, directory '/usr/local/hestia/nginx/logs' not empty so not removed
Processing triggers for systemd (245.4-4ubuntu3.24) ...
root@server ~ # apt install hestia-php hestia-nginx
Get:1 https://apt.hestiacp.com focal/main amd64 hestia-php amd64 8.3.16 [63.0 MB]
Fetched 63.0 MB in 1s (67.1 MB/s)
Selecting previously unselected package hestia-nginx.
(Reading database ... 50592 files and directories currently installed.)
Preparing to unpack .../hestia-nginx_1.27.3_amd64.deb ...
Unpacking hestia-nginx (1.27.3) ...
Selecting previously unselected package hestia-php.
Preparing to unpack .../hestia-php_8.3.16_amd64.deb ...
[ * ] File Manager is up to date (7.12.0)...
[ * ] Roundcube is up to date (1.6.9)...
[ ! ] Update Hestia PHP dependencies...
/usr/local/hestia/bin/v-add-sys-dependencies: line 69: /usr/local/hestia/php/bin/php: No such file or directory
Your lock file does not contain a compatible set of packages. Please run composer update.
ERROR: PHPMailer installation failed!
Please report this to our development team:
https://github.com/hestiacp/hestiacp/issues
[ * ] Updating Cloudflare IP Ranges for NGINX...
[ * ] phpMyAdmin is up to date (5.2.2)...
[ * ] Upgrading phppgadmin to version 7.14.6...
Installation tasks complete, performing clean-up...
[ * ] Rebuilding user accounts and domains, this may take a few minutes...
      - user...
      - user...
      - user...
      - user...
      - user...
      - user...
      - user...
[ * ] Restarting services...
/usr/local/hestia/bin/v-restart-proxy: /usr/local/hestia/web/inc/mail-wrapper.php: /usr/local/hestia/php/bin/php: bad interpreter: No such file or directory
Error: nginx restart failed
Error: ERROR: Restart of php8.1-fpm failed.
Error: ERROR: Restart of hestia failed.
Upgrade complete! If you encounter any issues or find a bug,
please take a moment to report it to us on GitHub at the URL below:
Read the release notes to learn about new fixes and features:
https://github.com/hestiacp/hestiacp/blob/release/CHANGELOG.md
We hope that you enjoy using this version of Hestia Control Panel,
have a wonderful day!
Sincerely,
The Hestia Control Panel development team
Web:      https://www.hestiacp.com/
Docs:     https://docs.hestiacp.com/
Forum:    https://forum.hestiacp.com/
GitHub:   https://github.com/hestiacp/hestiacp/
Help support the Hestia Control Panel project by donating via PayPal:
https://www.hestiacp.com/donate
Made with love & pride by the open-source community around the world.
/usr/local/hestia/func/upgrade.sh: /usr/local/hestia/web/inc/mail-wrapper.php: /usr/local/hestia/php/bin/php: bad interpreter: No such file or directory
0 upgraded, 2 newly installed, 0 to remove and 14 not upgraded.
Need to get 0 B/66.6 MB of archives.
Unpacking hestia-php (8.3.16) ...
Setting up hestia-php (8.3.16) ...
dpkg: error processing package hestia-php (--configure):
 installed hestia-php package post-installation script subprocess returned error exit status 5
 hestia-php
Hello everyone, I had exactly the same experience, I did everything that was said here, but it didn’t help… I need help!
https://server.domain.xyz:8083/login/
Unable to load required libraries. Please run v-add-sys-dependencies in command line. Error: Failed opening required ‘vendor/autoload.php’ (include_path=‘.:’)
Now run apt install hestia --reinstall again
