Automatic backups running every few seconds without cron job
I’m experiencing a strange issue with HestiaCP. Local backups are being created automatically every few seconds, even though I have no cron jobs configured for any user to trigger backups.
This happens between 5:00 and 9:00 AM and affects multiple users. Below is a short snippet of the log (there are hundreds of such entries):
yaml
KopiujEdytuj
20 Jun 2025 07:48:27 Backup created (User: [user1], Archive: 2025-06-20_07-48-13.tar).
20 Jun 2025 07:48:27 Backup created (User: [user1], Archive: 2025-06-20_07-48-12.tar).
20 Jun 2025 07:48:24 Backup created (User: [user1], Archive: 2025-06-20_07-48-07.tar).
20 Jun 2025 07:40:45 Backup created (User: [user1], Archive: 2025-06-20_07-40-38.tar).
20 Jun 2025 07:40:42 Backup created (User: [user2], Archive: 2025-06-20_07-40-37.tar).
Users anonymized in this post, but this repeats for several accounts. I’ve double-checked all cron jobs, both system-wide and user-level — none are related to backups.
Any ideas what could cause this behavior or how to debug it?
Thanks in advance!
cat /var/spool/cron/crontabs/hestiaweb
cat /usr/local/hestia/data/queue/backup.pipe
MAILTO=""
CONTENT_TYPE="text/plain; charset=utf-8"
*/2 * * * * sudo /usr/local/hestia/bin/v-update-sys-queue restart
10 00 * * * sudo /usr/local/hestia/bin/v-update-sys-queue daily
15 02 * * * sudo /usr/local/hestia/bin/v-update-sys-queue disk
10 00 * * * sudo /usr/local/hestia/bin/v-update-sys-queue traffic
30 03 * * * sudo /usr/local/hestia/bin/v-update-sys-queue webstats
*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-queue backup
20 00 * * * sudo /usr/local/hestia/bin/v-update-user-stats
*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-rrd
54 4 * * * sudo /usr/local/hestia/bin/v-update-letsencrypt-ssl
42 6 * * * sudo /usr/local/hestia/bin/v-update-sys-hestia-all
root@mail:/usr/local/hestia/data/users# cat /usr/local/hestia/data/queue/backup.pipe
I removed v-backup-users for testing, but it still creates backups every few seconds from 5 AM to 9 AM.
I’ve just noticed this… I’ll take a closer look at this command.
It looks like the issue is not caused by v-update-sys-queue backup
sudo /usr/local/hestia/bin/v-update-sys-queue backup checks every minute if backup.pipe contains a job but should never execute any thing if empty
Yes, I’ve read that. I’ve completely lost track of where to look for the cause of my issue.
Interesting issue…
Show the output of these commands (as root):
atq
systemctl list-timers --all --no-pager -l
grep -r backup /etc/cron* /var/spool/cron
/var/spool/cron/crontabs/hestiaweb.vst.back:*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-queue backup
/var/spool/cron/crontabs/hestiaweb.vst.back:00 22 * * * sudo /usr/local/hestia/bin/v-backup-users
/var/spool/cron/crontabs/ravczy:# For example, you can run a backup of all your user accounts
/var/spool/cron/crontabs/ravczy:# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
/var/spool/cron/crontabs/hestiaweb:*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-queue backup
/var/spool/cron/crontabs/hestiaweb:00 23 * * * sudo /usr/local/hestia/bin/v-backup-users
I noticed what seems to be a duplicate entry related to ‘backup users’ in the logs. I’ll extract the full logs from the server and review them in more detail to confirm.
Remove that file:
rm -f /var/spool/cron/crontabs/hestiaweb.vst.back
Use also this command to edit crontab and save (there is no need to modify anything, just edit and save):
crontab -e -u hestiaweb
You didn’t post the output of the above commands.
i’ll check this case tomorrow at the morning:) thx…
It looks like rm -f /var/spool/cron/crontabs/hestiaweb.vst.back helped. Now one backup is performed daily at the scheduled time.
Thank you Sahsanu!
