Hi, why can’t SSL automatically activate when a user registered to a new server, even waiting after 24hrs for propagation, unless he/she run’s the SSL installation manually before it worked, i have tried to write a script to force the SSL automatic activation, but it’s not working. I need some help and guide on this.
I am running a hosting business so i use Hestia as part of my control panel on shared hosting.
Currently Hestia doesn’t support such feature, you must enable it manually. Keep in mind that some users doesn’t need/want a Let’s Encrypt certificate, maythe they want to use its own certificate or a self-signed cert…
Greetings, i tried writing a script to force automatic SSL Activation which will be on PHP end point. But since you said Hestia only accept manual SSL Installation, that’s good.
