I want to disable WordPress Cron and fire the cron through Hestia.
How do I do this?
A few blogs suggest adding the following to the control panel
wget -q -O - https://domain.com/wp-cron.php?doing_wp_cron >/dev/null 2>&1
I came across a thread in another language where it seemed like I have to add the following to the cron job:
/usr/local/bin/php /home/USERNAME/web/DOMAINNAME.com/public_html/wp-cron.php >/dev/null 2>&1
In the above code I replaced the USERNAME and DOMAINNAME.com with the my hestia values.
Should I prefix the following in the front for the chron to work?
wget -q -O -
