Awstats not accessible
I am trying to access awstats, but when loading domain.tld/vstats & /awstats & /stats, all i do is get redirected to the 404 page.
I have checked the config files, and they all are saying it uses /vstats
Thanks in advance
Did you enable it for the webdomain?
Btw. you should try adding a / at the end. That helps :slight_smile:
https://domain.tld/vstats/
