AWstats not resolving ipaddresses
Perhaps this comment is useful for somebody with the same problem.
After a vanilla install of my server & hestiacp, awstats did not resolved ipaddresses into hostnames.
The file /etc/awstats/awstats.conf contained the line
DNSLookup=1
I manually added that same line to all the websites awstats configuration files in /etc/awstats (awstats.{domain}.conf) and the resolving started to work.
It will get reset when it updates hestia or you update the web site settings
We should make the changes with a pr or update it with a hook that runs every update
Yeah, it is probably better to add that line to /usr/local/hestia/data/templates/web/awstats/awstats.tpl
I would love to make a PR but sadly don’t know how.
Do you want to enable “Country” report?
In that case:
Gives a more improved result
Nope, but thank you for the excellent suggestion.
