zak
1
I’m using remote backup backblaze, the problem occurs when I save the Application Key, hestia saves it in the wrong format.
Example :
application key : K004Tw5HCvcJ9L1MiB/iVEv++0TaIRQ
saved : K004Tw5HCvcJ9L1MiB\/iVEv\+\+0TaIRQ
we can see it in /usr/local/hestia/conf/b2.backup.conf
The problem is, some characters change when saved:
/ changed into \/
+ changed to \+
temporary solution :
change the value in /usr/local/hestia/conf/b2.backup.conf
thanks
eris
2
I have added a link with more information.
It is probally due to the use of escapeargs function
