I am trying to restore a backup on another host with the same configuration options, different OS.
It does not restore the DBs, the output of the restore command for the DB part is:
-- DB --
2024-07-27 04:07:50 admin_example
/backup/tmp.q9tXtL1Qpl/db/admin_example/admin_example.mysql.sql.zst: 10969823 bytes
2024-07-27 04:07:51 admin_example
/backup/tmp.q9tXtL1Qpl/db/admin_example/admin_example.mysql.sql.zst: 1065932 bytes
2024-07-27 04:07:52 admin_example
/backup/tmp.q9tXtL1Qpl/db/admin_example/admin_example.mysql.sql.zst: 126444874 bytes
2024-07-27 04:07:53 admin_example
/backup/tmp.q9tXtL1Qpl/db/admin_example/admin_example.mysql.sql.zst: 1279265 bytes
2024-07-27 04:07:54 admin_of
/backup/tmp.q9tXtL1Qpl/db/admin_example/admin_example.mysql.sql.zst: 122220 bytes
2024-07-27 04:07:55 admin_example
/backup/tmp.q9tXtL1Qpl/db/admin_example/admin_example.mysql.sql.zst: 26847374 bytes
2024-07-27 04:07:56 admin_example
/backup/tmp.q9tXtL1Qpl/db/admin_example/admin_example.mysql.sql.zst: 7483336 bytes
the tmp. folder do not exist after the restore is complete.
Any tips on getting the restore to work also for the DBs?
Br,
Fred
