Hi!
I just add ftp xxx.xxx.xxx.xxx:13
Error: invalid host format :: xxx.xxx.xxx.xxx:13
Debian 9 / 1.1.1 (amd64)
Hi!
How you added it, over backend or cli? Could you probaly share the steps so we can try to reproduce it on out side?
Modify /usr/local/hestia/conf/ftp.backup.conf and change the port number
It should work
If so please create a bug report reminding us with this issue and also not that it is the same for sftp
If you use CLI the correct format is:
v-add-backup-host HOST USERNAME PASSWORD [PATH] [PORT]
So
v-add-backup-host ftp.server.nl user password /backup 13
Just opened the issue to track it down: https://github.com/hestiacp/hestiacp/issues/850
Thank you, my friends
ftp.backup.conf
HOST='ftp_host'
USERNAME='login'
PASSWORD='password'
BPATH='/backup'
PORT='13'
/usr/local/hestia/conf/hestia.conf
edit
BACKUP_SYSTEM='local'
BACKUP_SYSTEM='local,ftp'
