Backup on Remote B2
I try to backup to B2. because I don’t have enough space on local server,
but the backup command also check space on local disk,
How I can backup directly to B2.?
We don’t support direct backups to B2. There is still a file created on the server and afterwards uploaded to B2 and deleted localy when completed.
Ok
The local file, I have to delete or It will get auto delete
Will get deleted by default unless you set “local” to be kept
