Backup periodicity
Hello guys, is that possible to set hestia users backup for once in a month or once in a week?
You can create under the admin user a cronjob with
sudo /usr/local/hestia/bin/v-backup-user user
With the cron settings you want…
How ever you can’t exclude a user from v-backup-users cronjob…
Is that possible that this option (in panel) will be in the next updates?
Can I create this backup periodicity for all users from this command?
sudo /usr/local/hestia/bin/v-backup-users
Yes…
You probally need to delete the currently existing backup…
Ok, thank you eris!
