BACKUPS failed create impossible
hi, sorry my english is bad, i need help :
  1. i had 1 backup failed, i try to create one more but hestiacp say “impossible to create because one run already !”
    i try to add 1 number backup more, but i must wait this night
  2. i would try find other community help french user for discuss and help friendly.
    I don’t find how contact admin here with simple message.
Thanks for your help guys
cat /usr/local/hestia/data/queue/backup.pipe
thanks , i understand, i do this , i have run, i wait the creation arrive.
can i see and follow avanced run ? how can i know please ?
thanks
From Hestia CP Web UI you can click on button Créer une sauvegarde and in a few minutes you should get the backup:
Or from command line, as root:
v-backup-user HereYourUser
Thank you very much, i solved this problem with both solution !!!
thanks
ps : if un admin could send me a friendly partner french on forum ?
THANKS !!!
I don’t know anyone on the forum who speaks french. I looked to see if there was a Hestia group in french on Telegram but I didn’t find any.
There are a few translators like deepl.com out there that can help you to post here in english.
