Backups not finish been generated
Hello!
Backups get stuck generating and never finish.
I try to make one and it tells me that there is another in process that never ends.
As I did in vesta, I have tried to delete the backup.pipe file and recreate it, then delete the
rm /usr/local/hestia/data/queue/backup.pipe
touch /usr/local/hestia/data/queue/backup.pipe
this let me re-create a new one, but the creation process does not finish anyway :frowning:
v-backup-users and see what going wrong
i try
v-backup-users
but noting happen. i check cronjobs and are ok.
v-backup-user admin
i have this problem. anyone can help me?
Check your logs
hi, check your space on disk :face_with_monocle:
i have 50G disk and just 16G is used. when click on the create backup show me ‘An existing backup is already running. Please wait for that backup to finish.’ but about 1mount ago ran.in hestia panel log not insert new row about backup.
with new user i can create new backup but i need create backup with previous user
check plz
No need to double post, you’ll get an answer as soon as someone has time for it :slight_smile:.
I suggest to reboot the server, empty the backup pipe:
And manualy run the backup to validate the functionality: v-backup-user username
thank you solved
Would you let use please know, what the solution was?
I have the same problem and I cleared the backup pipe file.
When I run the backup script, I get a message
Error: not enough diskspace available to perform the backup.
Does it mean that I dont have space for the user or dont have space in the backup folder?
Backup and home folder is partitioned by the way.
Furthermore, I have lots of space for home and the backup.
So my question is what does the error message means? Does it mean for the user plan?
Permission issue? I have other users with no problem
Please use the search function, it will provide youna thread with enough informations to answer your questions: Error: not enough diskspace available to perform the backup
If you still have questions, open a new thread - dont revive the “deads”.
