From shell the below command works to create a backup then sends backup email and shows in the console. All scheduled backups are failing, /var/log/hestia/backup.log shows nothing is being written to them when scheduled backups are set. only when the shell command is run does anything write to logs.
sudo /usr/local/hestia/bin/v-backup-user admin yes >> /usr/local/hestia/log/backup.log 2>&1
I cannot see where backups are scheduled by Hestia.
Cron seems to be running other jobs in syslog, my next step is to manually add a cron job.
Thanks and love the Hestia project its just what Vesta needed. ![]()
