@Raphael is coming back from Holiday. After that we should be ready for the release. We are mostly busy with the last few bug fixes…
What are the approximate release dates? Any approximate dates?
As soon as I’m back and the release is working properly, we usualy do not give out a specific time for the release - that only stress us out and makes you unhappy, if we cant hold it due to latest bugs or different things.
That‘s the Debian way of doing releases and I like it ![]()
Hello!
If I do a fresh install of Hestia 1.6 Beta - when it is released, will I stay in the beta channel or switch to stable automatically?
After 1.6.0 is released
It will be removing an # in the hestia.list for the apt.hestiacp.com and add an # in front of beta.hestiacp.com
usr\local\hestia\data\firewall\custom.sh
Not work in this version?
iptables does not respond to changes
Make sure it is able executable…
Sorry, my mistake, dont give permissions on file ![]()
MariaDB is installed, but not have DB in control panel, but i think you know this ![]()
If it is under then admin user create a new user
New user has DB, but how i can add it to exist admin user?
There is no reason to add it. As it a bad security practice to host any side on the admin “user” as it has increased access to the server. If you website got hacked users can run certain code and gain access to the panel
Why CLAMAV-daemon automacally stoped after some time?
1.6rc1
RAM 2,5Gb
Check the log files. I can’t debug your server…
Probally not enough memory.
SMTP error (-1): Failed to connect to the server.
But exim is running…
If you want me to debug. Hourly rate it 100 usd. Please provide with more info because I can’t guess what is wrong
Maybe it is beta bug? No?
What info you need? I give it
I don’t know what is not working or what is generating this issue. So default steps like:
- Steps that you have taken
- Related log files
- Custom changes
And so.
Hestia is opensource this means so it will also mean that you have to debug and check what is wrong.
Can be everything it depends on the context. But if ClamAV is down it might be a good start point for debugging
roundcube log:
[07-Jun-2022 21:00:59 Europe/Kiev] PHP Deprecated: Return type of zipdownload_mbox_filter::filter($in, $out, &$consumed, $closing) should either be compatible with php_user_filter::filter($in, $out, &$consumed, bool $closing): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /var/lib/roundcube/plugins/zipdownload/zipdownload.php on line 405
[07-Jun-2022 21:00:59 Europe/Kiev] PHP Deprecated: strlen(): Passing null to parameter #1 ($string) of type string is deprecated in /var/lib/roundcube/program/actions/mail/index.php on line 181
[07-Jun-2022 21:00:59 Europe/Kiev] PHP Warning: stream_socket_client(): Unable to connect to localhost:587 (Connection refused) in /var/lib/roundcube/vendor/pear/net_socket/Net/Socket.php on line 159
[07-Jun-2022 21:00:59 +0300]: <n1u0i151> PHP Error: Connection refused (POST /?_task=mail&_unlock=loading1654624860199&_framed=1&_action=send)
[07-Jun-2022 21:00:59 +0300]: <n1u0i151> PHP Error: Failed to connect socket: Connection refused (POST /?_task=mail&_unlock=loading1654624860199&_framed=1&_action=send)
[07-Jun-2022 21:00:59 +0300]: <n1u0i151> SMTP Error: Connection failed: Failed to connect socket: Connection refused in /var/lib/roundcube/program/lib/Roundcube/rcube.php on line 1774 (POST /?_task=mail&_unlock=loading1654624860199&_framed=1&_action=send)
[07-Jun-2022 21:01:00 Europe/Kiev] PHP Deprecated: Return type of zipdownload_mbox_filter::filter($in, $out, &$consumed, $closing) should either be compatible with php_user_filter::filter($in, $out, &$consumed, bool $closing): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /var/lib/roundcube/plugins/zipdownload/zipdownload.php on line 405
[07-Jun-2022 21:01:00 Europe/Kiev] PHP Deprecated: strlen(): Passing null to parameter #1 ($string) of type string is deprecated in /var/lib/roundcube/program/actions/mail/index.php on line 181
smtp log:
[07-Jun-2022 21:04:07 +0300]: <n1u0i151> Connecting to localhost:587...
[07-Jun-2022 21:12:45 +0300]: <n1u0i151> Connecting to localhost:587...
[07-Jun-2022 21:17:56 +0300]: <n1u0i151> Connecting to localhost:587...
[07-Jun-2022 21:36:41 +0300]: <n1u0i151> Connecting to localhost:587...
