This can be fix with " systemctl enable named or ?
Thank you
Thank you
You must first find out why the service is not starting.
Check whether the service is enabled:
systemctl is-enabled named
Reboot the server and immediately check the service and the log:
systemctl status named --no-pager -l
grep named /var/log/syslog | tail -n50
Yes, running systemctl enable named will ensure BIND starts automatically on reboot.
if BIND still doesn’t start after enabling the service you might be running into a system-level issue related to networking or binding permissions. I had a similar issue in the past and resolved it by adding the following to /etc/sysctl.conf:
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv4.ip_nonlocal_bind = 1
vm.overcommit_memory = 1
After saving, run sysctl -p to apply the changes, then try rebooting and see if BIND starts as expected.
Let me know how it goes.
