Bind9 restart failed
I recently see this error “bind9 restart failed” everything I made changes to the server. Don’t know why.
Check log files
systemctl status bind9
After running that command, I see this error:
Blockquote network unreachable
I updated Debian 9.12 on the server. The problem seems to be gone.
I have noticed the same problem on 2 HestiaCP servers with automatic updates enabled (Debian 10).
The recent Debian 10.5 upgrade of
bind9 bind9-host bind9utils dnsutils libbind9-161 libdns-export1104 libdns1104 libirs161 libisc-export1100 libisc1100 libisccc161 libisccfg163 liblwres161
which failed to complete, bind9 failed to restart. However bind9 started successfully after a reboot, but failed again the next day, upon “apt upgrade” …
root@mysrv:~# systemctl status bind9.service
● bind9.service - BIND Domain Name Server
   Loaded: loaded (/lib/systemd/system/bind9.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Fri 2020-08-28 07:43:15 EEST; 19h ago
     Docs: man:named(8)
  Process: 9219 ExecStart=/usr/sbin/named $OPTIONS (code=exited, status=1/FAILURE)
Aug 28 07:43:15 mysrv.mydomain.tld systemd[1]: Starting BIND Domain Name Server...
Aug 28 07:43:15 mysrv.mydomain.tld systemd[1]: bind9.service: Control process exited, code=exited, status=1/FAILURE
Aug 28 07:43:15 mysrv.mydomain.tld systemd[1]: bind9.service: Failed with result 'exit-code'.
Aug 28 07:43:15 mysrv.mydomain.tld systemd[1]: Failed to start BIND Domain Name Server.
root@mysrv:~#
This happened on two different systems running stock Debian 10 with HestiaCP.
The bind9 update didn’t fully complete:
# tail /var/log/dpkg.log
2020-08-28 05:44:30 status half-configured bind9-host:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-28 05:44:30 status installed bind9-host:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-28 05:44:30 configure dnsutils:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2 <none>
2020-08-28 05:44:30 status unpacked dnsutils:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-28 05:44:30 status half-configured dnsutils:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-28 05:44:30 status installed dnsutils:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-28 05:44:30 configure bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2 <none>
2020-08-28 05:44:30 status unpacked bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-28 05:44:30 status half-configured bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-28 05:44:32 trigproc systemd:amd64 241-7~deb10u4 <none>
2020-08-28 05:44:32 status half-configured systemd:amd64 241-7~deb10u4
2020-08-28 05:44:32 status installed systemd:amd64 241-7~deb10u4
2020-08-28 05:44:32 trigproc libc-bin:amd64 2.28-10 <none>
2020-08-28 05:44:32 status half-configured libc-bin:amd64 2.28-10
2020-08-28 05:44:32 status installed libc-bin:amd64 2.28-10
2020-08-28 07:43:04 startup packages configure
2020-08-28 07:43:04 configure bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2 <none>
2020-08-28 07:43:04 status half-configured bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-28 07:43:08 startup packages configure
2020-08-28 07:43:08 configure bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2 <none>
2020-08-28 07:43:08 status half-configured bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-28 07:43:13 startup packages configure
2020-08-28 07:43:13 configure bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2 <none>
2020-08-28 07:43:13 status half-configured bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-29 07:43:04 startup packages configure
2020-08-29 07:43:04 configure bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2 <none>
2020-08-29 07:43:04 status half-configured bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-29 07:43:08 startup packages configure
2020-08-29 07:43:08 configure bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2 <none>
2020-08-29 07:43:08 status half-configured bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
2020-08-29 07:43:13 startup packages configure
2020-08-29 07:43:13 configure bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2 <none>
2020-08-29 07:43:13 status half-configured bind9:amd64 1:9.11.5.P4+dfsg-5.1+deb10u2
and I got e-mails from both HestiaCP servers (note: autoupdate was enabled):
Subject: Cron <admin@mysrv> sudo /usr/local/hestia/bin/v-update-sys-hestia-all
Error: hestia update failed
Error: hestia-nginx update failed
Error: hestia-php update failed
Maybe try
dpkg --configure -a
I solved it, failure to load bind9 was due to AppArmor …
I finally decided to set all AppArmor profiles to “complain” mode, until I have the time to properly debug it.
