Bind9 zone permission denied!
Hello!
My problem all DNS:
/home/apple-1/conf/dns/apple.hu.db failed: permission denied
/home/example-1/conf/dns/example.com.db failed: permission denied
etc…
It could be a few days. Because I noticed that I wanted to change the name server on one of the domains that had been modified for 2 weeks, so it was still good then. Since then, the server has not even been accessed in ssh.
Premissions:
/home/apple-1/conf/dns/apple.hu.db 640 root:bind
/home/example-1/conf/dns/example.com.db 640 root:bind
What could be the problem? In the past, these were rights, then there was no problem with him.
This is a problem with all hosting. (all users)
Users arent able to access or modify any files in /home/conf/* by design, this isnt a bug nor an issue.
aug 16 16:24:48 server1.myserver.hu named[453]: zone apple.hu/IN: loading from master file /home/apple-1/conf/dns/apple-1.hu.db failed: permission denied
aug 16 16:24:48 server1.myserver.hu named[453]: zone apple.hu/IN: not loaded due to errors.
aug 16 16:24:48 server1.myserver.hu named[453]: zone example.com/IN: loading from master file /home/example-1/conf/dns/example.com.db failed: permission denied
aug 16 16:24:48 server1.myserver.hu named[453]: zone example.com/IN: not loaded due to errors.
aug 16 16:24:48 server1.myserver.hu named[453]: all zones loaded
aug 16 16:24:48 server1.myserver.hu named[453]: running
aug 16 16:24:48 server1.myserver.hu named[453]: zone 127.in-addr
and does not load them because the domain check throws an error on it.
M-PRIF -E- [apple.hu] Cannot get domain data (ns1.myserver.hu: myserv_ip)
Can you run a v-rebuild-user for every user and check, if it fixes the issue?
don’t fix :frowning:
I tried, but unfortunately not good still.
what do the permisions of the folder higher up look like?
/home
/home/{user}
/home/{user}/conf
/home/{user}/conf/dns
most likely you are missing x rights at some level, so named can’t change into the folders.
I still believe you messed up the permissions on your whole system at some point, by blindly running recursive chmod one high-up dir which removed the executable rights from your folders and now you see the outcome on different services.
home: 755 root:root
home/apple-1 755 root:root
home/apple-1/conf 755 root:root
home/apple-1/conf/dns 751 root:root
home/apple-1/conf/dns/* 640 root:bind
solved:
/etc/apparmor.d/usr.sbin.named Add this line:
/home/** rwm,
Underneath
/etc/bind/** rw,
and service apparmor restart
and working! :)) :slight_smile: thanks.
