Blesta and HestiaCP
Does anyone use blesta and HestiaCP? it doesnt let me create packages etc…
Add your public ip to the white list…
i did, add the public ip and on second line the local ip and getting this error:
|v-add-user
a:2:{s:6:“status”;s:5:“false”;s:8:“response”;s:44:“Error: IP is not allowed to connect with API”;}
Are you using Cloudflare?
In that case use:
allow-all
I am not using cloudflare but where should i add the allow-all to make this test couldnt understand
You can always add “allow-all” it will by pass the check…
This did the trick but i dont know if its the best solution!
Check /var/log/hestia/auth.log what ip was used connecting and add it to the whitelist
