Blesta SSL Error
Please Help.
my custom Template Working Fine on Blesta.
But when Try install ssl using my Template SSL not Installed.
Error - Error: Let's Encrypt validation status 400 (domain.net). Details: 403:"213.199.36.109: Invalid response from http://domain.net/.well-known/acme-challenge/HyLwM5JZLwc6KB2VwdY0OP-KhE03r32lTMSB-kaCV1E: 404"
My Blesta tpl -
server {
        listen  %ip%:%web_port%;
        root        %docroot%/blesta;
        # Include SSL forcing config (if applicable)
        # iFrame protection
        add_header X-Frame-Options SAMEORIGIN;
        location / {
                try_files $uri $uri/ /index.php?$query_string;
                rewrite ^(.*)/install.php$ /$1/install/redirect;
        # PHP-FPM configuration for index.php
        location = /index.php {
                fastcgi_index index.php;
                fastcgi_pass %backend_lsnr%;
        # Security: Block access to certain file types
        location ~ /\. {
                log_not_found off;
                return 404;
        # Block access to specific file types
        location ~* \.(php|pdt|txt)$ {
                log_not_found off;
                return 404;
        # Handle custom error pages
        location /error/ {
        # Handle vstats (web stats) access
        location /vstats/ {
        # Include additional configurations
blesta stpl -
server {
    listen      %ip%:%web_ssl_port% ssl;
    # Root location block (Update %docroot%/blesta to your own Directory / @blesta is Default)
    root        %sdocroot%/blesta;
        # SSL Configuration
        ssl_stapling        on;
        ssl_stapling_verify on;
        # ACME Challenge directory for SSL renewal
        location ^~ /.well-known/acme-challenge/ {
            root %sdocroot%;
            allow all;
        # TLS 1.3 0-RTT anti-replay
        # Security: HSTS
        # iFrame protection
        # Main location block
        location / {
        location ~ /\. {
                log_not_found off;
                return 404;
        # Block access to specific file types (e.g., PHP scripts, PDT, TXT files)
                log_not_found off;
                return 404;
        # Error page location
        location /error/ {
        # vStats location
        location /vstats/ {
Please help me when i’ve used Custom Root location block - root %sdocroot%/blesta;
How to Fix SSL Install Error?
In blesta.stpl template modify this include:
to this:
Rebuild your web site and try again.
Also probally remove:
            root %sdocroot%;
            allow all;
Still now SSL not Installed… :frowning:
Also try using Others Domain.
When Select Blesta Template SSL not Installed, but SSL Installed Fine when Select Others Templates
Move this include:
below the first include:
I’ve modifed both templates (I’ve tested them and it works using these templates):
blesta.tpl
server {
        # iFrame protection
        location / {
        location ~ /\. {
                log_not_found off;
                return 404;
                log_not_found off;
                return 404;
        location /error/ {
        location /vstats/ {
blesta.stpl
server {
        # SSL Configuration
        ssl_stapling        on;
        # Security: HSTS
        # iFrame protection
        location / {
        location ~ /\. {
                log_not_found off;
                return 404;
                log_not_found off;
                return 404;
        location /error/ {
        # vStats location
        location /vstats/ {
Thanks @sahsanu
Its Now Working… :revolving_hearts:
