BookStack HestiaCP One-Click Installation Setup
1. Create Installer Files
Directory: /usr/local/hestia/web/src/app/WebApp/Installers/BookStack/
Files:
  • BookStackSetup.php
  • bookstack-logo.svg
1.1 bookstack-logo.svg
<svg xmlns="http://www.w3.org/2000/svg" height="61.699mm" width="65.023mm" version="1.1" viewBox="0 0 230.39711 218.6199" aria-label="BookStack Logo">
 <g stroke-linejoin="round" fill-rule="evenodd" transform="translate(-245.27 -58.434)" stroke="#0288d1" stroke-width="6" fill="#fff">
  <g stroke-linecap="round">
   <path d="m343.79 238.6 128.88-74.409-92.058-53.15-128.88 74.409z"/>
   <path d="m251.73 185.45v21.26l92.058 53.15 128.88-74.409v-21.26"/>
   <path d="m343.79 274.03-92.058-53.15s-7.5-16.918 0-28.346l92.058 53.15 128.88-74.409v28.346l-128.88 74.409"/>
   <path d="m343.79 188.99 128.88-74.41-92.06-53.146-128.88 74.406z"/>
   <path d="m343.79 188.99 128.88-74.409 0.00001 28.346-128.88 74.409-92.058-53.15s-6.0714-17.632 0-28.346z"/>
   <path d="m343.79 245.69-92.058-53.15s-7.5-16.918 0-28.346l92.058 53.15 128.88-74.409-0.00001 28.346-128.88 74.409"/>
  </g>
  <path d="m402.09 73.836-55.234 31.89 21.48 1.7716 3.0686 12.402 55.235-31.89z"/>
 </g>
</svg>
1.2 BookStackSetup.php
<?php
declare(strict_types=1);
namespace Hestia\WebApp\Installers\BookStack;
use Hestia\System\Util;
use Hestia\WebApp\BaseSetup;
use Hestia\WebApp\InstallationTarget\InstallationTarget;
class BookStackSetup extends BaseSetup {
    protected array $info = [
        "name" => "BookStack",
        "group" => "cms",
        "version" => "latest",
        "thumbnail" => "bookstack-logo.svg",
    protected array $config = [
        "form" => [
            "site_name" => ["type" => "text", "value" => "BookStack"],
            "username" => ["value" => "admin"],
            "email" => "text",
            "password" => "password",
        "database" => true,
        "resources" => [
            'archive' => [
                'src' => 'https://codeberg.org/bookstack/bookstack/archive/v26.05.5.tar.gz',
                'dst' => '/'
        "server" => [
            "nginx" => [
                "template" => "bookstack",
            "php" => [
                "supported" => ["8.1", "8.2", "8.3", "8.4", "8.5"],
    protected function setupApplication(InstallationTarget $target, array $options = null): void {
        $docroot = $target->getDocRoot();
        $phpVersion = $options['php_version'];
        $this->moveNestedDirectory($docroot);
        $this->setupEnvFile($target, $options);
        $this->appcontext->runPHP($phpVersion, $docroot . '/bookstack-system-cli', [
            'download-vendor'
        $this->appcontext->runPHP($phpVersion, $docroot . '/artisan', [
            'key:generate',
            '--no-interaction',
            '--force'
            'migrate',
            '--no-interaction',
            '--force'
        $this->updateAdmin($docroot, $phpVersion, $options);
    private function updateAdmin(string $docroot, string $phpVersion, array $options): void {
        $email    = trim($options['email'] ?? '');
        $username = trim($options['username'] ?? '');
        $password = trim($options['password'] ?? '');
        if (empty($email))    { $email    = '[email protected]'; }
        if (empty($username)) { $username = 'Admin'; }
        if (empty($password)) { $password = 'password'; }
        $script = $docroot . '/update_admin.php';
        $emailEsc    = addslashes($email);
        $usernameEsc = addslashes($username);
        $passwordEsc = addslashes($password);
        $content = '<?php
require "' . $docroot . '/vendor/autoload.php";
$app = require "' . $docroot . '/bootstrap/app.php";
$app->make(\Illuminate\Contracts\Console\Kernel::class)->bootstrap();
$user = \BookStack\Users\Models\User::where("email", "[email protected]")->first();
if (!$user) {
    $user = \BookStack\Users\Models\User::where("email", "' . $emailEsc . '")->first();
if ($user) {
    if ("' . $emailEsc . '" !== "[email protected]" && "' . $emailEsc . '" !== $user->email) {
        $exists = \BookStack\Users\Models\User::where("email", "' . $emailEsc . '")->first();
        if ($exists) {
            echo "Email already used: ' . $emailEsc . '\n";
        } else {
            $user->email = "' . $emailEsc . '";
    $user->name = "' . $usernameEsc . '";
    $user->password = bcrypt("' . $passwordEsc . '");
    $user->email_confirmed = 1;
    $user->save();
    $adminRole = \BookStack\Users\Models\Role::getSystemRole("admin");
    if ($adminRole) {
        $user->attachRole($adminRole);
        $user->save();
    echo "Admin updated\n";
    echo "Email: " . $user->email . "\n";
    echo "Password: ' . $passwordEsc . '\n";
} else {
    echo "Admin not found\n";
        $this->appcontext->createFile($script, $content);
        $this->appcontext->runPHP($phpVersion, $script, []);
        $this->appcontext->deleteFile($script);
    private function moveNestedDirectory(string $docroot): void {
        $dirs = glob($docroot . '/bookstack-*');
        foreach ($dirs as $dir) {
            if (is_dir($dir)) {
                $this->moveFiles($dir, $docroot);
                $this->removeDir($dir);
                break;
    private function setupEnvFile(InstallationTarget $target, array $options): void {
        $env_file = $docroot . '/.env.example';
        if (!file_exists($env_file)) {
            return;
        $env_content = file_get_contents($env_file);
        $env_content = preg_replace('/^APP_URL=.*$/m', 'APP_URL=' . $target->getUrl(), $env_content);
        $env_content = preg_replace('/^DB_DATABASE=.*$/m', 'DB_DATABASE=' . $target->database->name, $env_content);
        $env_content = preg_replace('/^DB_USERNAME=.*$/m', 'DB_USERNAME=' . $target->database->user, $env_content);
        $env_content = preg_replace('/^DB_PASSWORD=.*$/m', 'DB_PASSWORD=' . $target->database->password, $env_content);
        $this->appcontext->createFile($docroot . '/.env', $env_content);
    private function moveFiles(string $src, string $dst): void {
        $files = $this->appcontext->listFiles($src);
        foreach ($files as $file) {
            if ($file == '.' || $file == '..') {
                continue;
            $src_path = $src . '/' . $file;
            $dst_path = $dst . '/' . $file;
            if (is_dir($src_path)) {
                if (!is_dir($dst_path)) {
                    mkdir($dst_path, 0755, true);
                $this->moveFiles($src_path, $dst_path);
            } else {
                rename($src_path, $dst_path);
    private function removeDir(string $dir): void {
        if (!is_dir($dir)) {
            return;
        $files = scandir($dir);
                continue;
            $path = $dir . '/' . $file;
            if (is_dir($path)) {
                $this->removeDir($path);
            } else {
                unlink($path);
        rmdir($dir);
2. Create Nginx Templates
Directory: /usr/local/hestia/data/templates/web/nginx/php-fpm/
Files:
  • bookstack.tpl
  • bookstack.stpl
2.1 bookstack.tpl
server {
        listen      %ip%:%web_port%;
        root        %docroot%/public;
        location = /favicon.ico {
                log_not_found off;
                access_log off;
        location = /robots.txt {
                allow all;
                log_not_found off;
                access_log off;
                deny all;
                return 404;
        location / {
                        expires 30d;
                location ~ [^/]\.php(/|$) {
                        try_files $uri =404;
                        fastcgi_index index.php;
                        fastcgi_pass %backend_lsnr%;
        location /error/ {
        location /vstats/ {
2.2 bookstack.stpl
server {
        listen      %ip%:%web_ssl_port% ssl;
        root        %sdocroot%/public;
                log_not_found off;
                access_log off;
                allow all;
                log_not_found off;
                access_log off;
                deny all;
                return 404;
        location / {
                        expires 30d;
        location /error/ {
        location /vstats/ {
        proxy_hide_header Upgrade;
3. One-Click Script
Save as /root/add-bookstack.sh, then run it.
#!/bin/bash
# BookStack HestiaCP add script
# Creates four files in their corresponding locations
set -e
# Colors
RED='\033[0;31m'
GREEN='\033[0;32m'
YELLOW='\033[1;33m'
NC='\033[0m'
# Check root
if [ "$EUID" -ne 0 ]; then
    echo -e "${RED}Error: Please run as root${NC}"
    exit 1
fi
# Paths
INSTALLER_DIR="/usr/local/hestia/web/src/app/WebApp/Installers/BookStack"
TEMPLATE_DIR="/usr/local/hestia/data/templates/web/nginx/php-fpm"
echo -e "${GREEN}=== BookStack HestiaCP Add Script ===${NC}"
echo ""
# 1. Create Installers directory
echo -e "${YELLOW}[1/4] Creating Installers directory...${NC}"
mkdir -p "$INSTALLER_DIR"
echo "  $INSTALLER_DIR"
# 2. Create BookStackSetup.php
echo -e "${YELLOW}[2/4] Creating BookStackSetup.php...${NC}"
cat > "$INSTALLER_DIR/BookStackSetup.php" << 'PHPEOF'
<?php
        "group" => "cms",
        "form" => [
            "email" => "text",
        "database" => true,
        "resources" => [
            'archive' => [
                'dst' => '/'
        "server" => [
            "nginx" => [
            "php" => [
            'download-vendor'
            'key:generate',
            '--no-interaction',
            '--force'
            'migrate',
            '--no-interaction',
            '--force'
        $content = '<?php
if (!$user) {
if ($user) {
        if ($exists) {
        } else {
    $user->save();
    if ($adminRole) {
        $user->save();
} else {
            if (is_dir($dir)) {
                break;
            return;
                continue;
            } else {
            return;
                continue;
            } else {
                unlink($path);
        rmdir($dir);
PHPEOF
echo "  $INSTALLER_DIR/BookStackSetup.php"
# 3. Create bookstack-logo.svg
echo -e "${YELLOW}[3/4] Creating bookstack-logo.svg...${NC}"
cat > "$INSTALLER_DIR/bookstack-logo.svg" << 'SVGEOF'
  </g>
 </g>
</svg>
SVGEOF
echo "  $INSTALLER_DIR/bookstack-logo.svg"
# 4. Create nginx templates
echo -e "${YELLOW}[4/4] Creating nginx templates...${NC}"
mkdir -p "$TEMPLATE_DIR"
# bookstack.tpl
cat > "$TEMPLATE_DIR/bookstack.tpl" << 'TPLEOF'
server {
                log_not_found off;
                access_log off;
                allow all;
                log_not_found off;
                access_log off;
                deny all;
                return 404;
        location / {
                        expires 30d;
        location /error/ {
        location /vstats/ {
TPLEOF
echo "  $TEMPLATE_DIR/bookstack.tpl"
# bookstack.stpl
cat > "$TEMPLATE_DIR/bookstack.stpl" << 'STPLEOF'
server {
                log_not_found off;
                access_log off;
                allow all;
                log_not_found off;
                access_log off;
                deny all;
                return 404;
        location / {
                        expires 30d;
        location /error/ {
        location /vstats/ {
STPLEOF
echo "  $TEMPLATE_DIR/bookstack.stpl"
# 5. Set permissions
echo -e "${YELLOW}[5/5] Setting permissions...${NC}"
chown -R root:root "$INSTALLER_DIR"
chmod -R 755 "$INSTALLER_DIR"
chmod 644 "$INSTALLER_DIR/BookStackSetup.php"
chmod 644 "$INSTALLER_DIR/bookstack-logo.svg"
chmod 644 "$TEMPLATE_DIR/bookstack.tpl"
chmod 644 "$TEMPLATE_DIR/bookstack.stpl"
# 6. Verify
echo ""
echo -e "${YELLOW}=== Verification ===${NC}"
echo ""
echo "File listing:"
ls -la "$INSTALLER_DIR/"
echo ""
ls -la "$TEMPLATE_DIR/"
echo ""
# 7. Restart HestiaCP
echo -e "${YELLOW}Restarting HestiaCP...${NC}"
systemctl restart hestia 2>/dev/null || true
echo -e "${GREEN}=== Installation Complete ===${NC}"
echo ""
echo "Next steps:"
echo "  1. Log in to HestiaCP (https://your-server:8083)"
echo "  2. Web → Add Web Domain → Quick Install App → BookStack"
echo "  3. After installation, go to the website settings and set 'Custom Document Root' to 'public', then save."
echo ""
Once added, you can perform a quick BookStack installation from the site management page in the 8083 panel. After installation, remember to go back one step and enter public in the Custom Document Root option for the current domain, then save. Thanks for your support, and feel free to share more guidance!
To keep the page in your preferred language after logging out, add the following line to the end of your .env file. For available language options, refer to Language & Locale Configuration · BookStack
APP_LANG=fr
APP_AUTO_LANG_PUBLIC=false
Would be great if you can add to the quick installer as well. :slightly_smiling_face:
Yes, that’s it, quick installation.
No no. I meant in the hestia git repo, add as a PR.
You can ask sahsanu or go submit it.
Thanks. I will try to get it done. Stuck with a lot of work. :slight_smile:
Submitted under PR: Added bookstack quick installer - Pull Request #5733 - hestiacp/hestiacp - GitHub
