I tried looking into /usr/local/hestia/web/edit/web/index.php to see if I could work out where the “Alternate” part is printed out, and replace them with (which would make more sense), but I can’t find it. I guess this isn’t a major issue for most people - but it does look messy on my sites when managing them (as it overlaps outside of the container div)
Alternatively - even just changing the “,” to ", " makes it properly wrap , so maybe that’s a better idea?
Awesome, thanks. I wasn’t too sure if it wanted doing in the PHP script (vs the template), but I think the change is small enough to just go in the template files
