Had a few issues with NGINX and APACHE2 conflicting since the past few updates, but now I have the following:
So whilst the site is functioning, the layout of the hestiacp site is all screwed up, any ideas how I can fix it?
Simon
Simon
ls -l /usr/local/hestia/web/css/themes/
If you get an error, reinstall hestia package:
apt install --reinstall hestia
ls: cannot access '/usr/local/hestia/web/css/themes/': No such file or directory
Ran the 2nd command, back up and running again, many thanks for the help
try checking the permissions on the folder
