[BUG] Custom document root resets to first site when toggling SSL
I have dozen of domains on my Hestia and I use Custom document root setting.
When I enable or disable SSL for a web domain in Hestia, the Custom document root setting is reset.
Actual result:
After saving, the Point to dropdown changes automatically to the first site in the list instead of the folder that was previously selected.
Expected result:
  • Changing the SSL setting should not modify the selected custom document root.
  • The Point to value must stay the same as it was before toggling SSL.
I’ve tried to reproduce the issue and the custom document root doesn’t change in my tests.
Could you please show the entire conf of one of those web domains?
v-list-web-domain YourUser YourDomain json
