My reasoning is simple. I maintain several awesome HestiaCP’s and would like a simple visual identification (apart from the url) to know which one I am using.
Again. Is there a way to change the string “Welcome to Hestia Control Panel” to add a Hostname at the end.
Thank you kindly,
Please disable any plugins/add-ons inside your browser or contact your system administrator. If you are the system administrator you can run v-change-sys-config-value ‘POLICY_CSRF_STRICTNESS’ ‘0’ as root to disable this check.
If you followed a bookmark or an static link please navigate to root
There is no need to disable CSRF POLICY (it is a security policy and it is recommended to keep it active) just don’t use the static link https://myhostname:8083/edit/server/whitelabel/ to modify whitelabel options and go to the config section step by step:
Login to HestiaCP with your admin user → Server Settings → Configure → Whitelabel
