Can I connect AWS RDS with HESTIACP? I want to keep my database server separate. Any chance?
Yes Hestia can connect with an RDS instance but is not able to create database in there unless you have full permissions
Yes, I already have an RDS instance using with Plesk, and I want to add that same one with Hestiacp. Can you please share the steps?
Any updates?
HestiaCP is opensource and we don’t get paid for our effort so accept that answers take a bit longer then you work wait a paid product like Plesk…
Yes it is possible
Run the command:
/usr/local/hestia/bin/v-add-database-host
https://docs.hestiacp.com/cli_commands/commands.html#v-add-database-host
Thank you ![]()
