Can it be migrated from CPanel?
Yes of course check the code how it works and write one by your self…
Developed by the team of Hestia. I think the possibilities are quite low due to low usage of I-MSCP and prefer to work on “Big” panels like Cpanel, Directadmin and Plesk as they have a larger use base…
@heart1010,
If you are able to find a script that works to move i-MSCP data to a Vesta backup format, it could likely be restored but this isn’t something we’ve tested or can provide support for at this time.
change filename to cpanel-backup.tar.gz and put it in /usr/local/hestia/bin/
v-import-cpanel backup.tar.gz
