Hello. I need to use old php 7.0, so I downgraded phpmyadmin to 4.9.10. Created db, user through Hestia, uploaded my db from Vesta, site works perfectly. But when I logging into Phpmyadmin with my db user, I got a message
“The phpMyAdmin configuration storage is not completely configured, some extended features have been deactivated.”
First install Hesita with php 8.0 add after you are done run:
v-add-web-php 7.4
And change the backend template in Edit web for the domain that needs to run php7.0 to the correct PHP version. This method you can keep using the last phpmyadmin including all the security updates 4.9.x is lacking.
Generally I did the same way: installed 8.0, later changed to 7.3 (because of one of cms modules) and after this went to 7.0 (because of other module encrypted with old ioncube). But I downgraded Phpmyadmin manually, just downloaded and put in a folder - I read Hestia not installing phpmyadmin because of old version on the reps.
Ok, I returned 8.0 version and setted up as default for system. After this I redownloaded last 5.2 phpmyadmin and replaced my.
And - the same problem, " The phpMyAdmin configuration storage is not completely configured, some extended features have been deactivated. [Find out why].
Or alternately go to ‘Operations’ tab of any database to set it up there."
