cp: cannot stat ‘/usr/local/hestia/install/deb/logrotate/httpd-prerotate/': No such file or directory
Failed to enable unit: Unit file /etc/systemd/system/systemd-timesyncd.service is masked.
Failed to start systemd-timesyncd.service: Unit systemd-timesyncd.service is masked.
cp: cannot stat ‘/usr/local/hestia/install/deb/sudo/admin’: No such file or directory
chmod: cannot access ‘/etc/sudoers.d/admin’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/deb/logrotate/hestia’: No such file or directory
rm: cannot remove ‘/var/log/hestia’: Is a directory
ln: failed to create symbolic link ‘/usr/local/hestia/log’: No such file or directory
touch: cannot touch ‘/usr/local/hestia/log/system.log’: No such file or directory
touch: cannot touch ‘/usr/local/hestia/log/nginx-error.log’: No such file or directory
touch: cannot touch ‘/usr/local/hestia/log/auth.log’: No such file or directory
touch: cannot touch ‘/usr/local/hestia/log/backup.log’: No such file or directory
chmod: cannot access ‘/usr/local/hestia/log’: No such file or directory
chmod: cannot access '/var/log/hestia/’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/packages’: No such file or directory
sed: can’t read /usr/local/hestia/data/packages/.pkg: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/deb/templates’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/templates/web/’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/templates/dns/’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/templates/web/unassigned/index.html’: No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/templates/web/skel/document_errors/‘: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/firewall’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/api’: No such file or directory
hst-install-debian.sh: line 1260: /usr/local/hestia/bin/v-generate-ssl-cert: No such file or directory
sed: -e expression #1, char 3: unexpected ,' sed: -e expression #1, char 1: unknown command:
[ * ] Enable SFTP jail…
Error: can’t enable sftp jail
It didn’t download the package what is your server ip?
