Can not open phpMyAdmin in Hestia CP 1.1.0
I make fresh install Hestia 1.1.0 (amd64), Debian 9.12, using this instructions:
wget https://raw.githubusercontent.com/hestiacp/hestiacp/release/install/hst-install.sh
bash hst-install.sh
I create test user, test db, then try to use button phpMyAdmin.
In browser I see message: Firefox cannot establish a connection to the server xx.xx.xx.xx (my server ip).
phpMyAdmin do not working.
Use v-add-letsencrypt-host to generate a valid let’s encrypt certificate for the hestia panel and services like exim and vsftpd. Then use only hostname to connect to the panel, then also pma should work properly.
Thanks, that solved my problem!
