Can we use Vesta theme for Hestiacp?
For example: [v1.0] ioTheme - new theme for VestaCP - Vesta Control Panel - Forum
Or
https://forum.vestacp.com/viewtopic.php?t=7234
Regards
Or
Regards
I dont think this will work, also the project seems to be abandoned - last change back in 2018.
You can still try to get it running or try to get in contact with the dev and ask him to support hestia.
Thanks!
This one is a little bit newer:
https://hwi.cdgtech.one/#/
Can it work?
Most easy way to keep this themes updated will be replace Hestiacp cas with theme css?
Try it your self… We don’t support it officially they maybe lacking behind in development as we introduced a lot new features…
