After upgrading, trying to access Hestia panel on port 8083 times out with an ERR_CONNECTION_TIMED_OUT
error. Tried to restart services (Hestia, Nginx) even rebooted server, but error keeps showing up.
I tried to change Hestia port from default one (8083) to something else, restarted Hestia service but the panel is still not showing up…
Checked Nginx log for Hestia panel (/var/log/nginx/domains/server.mydomain.com.log) but when trying to connect to Hestia port no connections are being logged…
Don’t know if this could have something to do with this issue, but when updating server I did an apt dist-upgrade
instead of an apt upgrade
command…
Systemctl status hestia
Active: active (running) since Tue 2022-11-29 21:31:22 UTC; 10h ago
Process: 7169 ExecStart=/etc/init.d/hestia start (code=exited, status=0/SUCCESS)
Tasks: 3 (limit: 4555)
Memory: 7.1M
CGroup: /system.slice/hestia.service
├─7195 nginx: master process /usr/local/hestia/nginx/sbin/hestia-nginx
├─7197 nginx: worker process
└─7198 php-fpm: master process (/usr/local/hestia/php/etc/php-fpm.conf)
Nov 29 21:31:22 server.mydomain.com systemd[1]: Starting LSB: starts the hestia control panel...
Nov 29 21:31:22 server.mydomain.com hestia[7169]: * Starting hestia-nginx hestia-nginx
Nov 29 21:31:22 server.mydomain.com hestia[7169]: ...done.
Nov 29 21:31:22 server.mydomain.com hestia[7169]: * Starting hestia-php hestia-php
Nov 29 21:31:22 server.mydomain.com systemd[1]: Started LSB: starts the hestia control panel.
@eris Any clue?
Can yo access ip:port?
curl -I IP:5656
HTTP/1.1 302 Moved Temporarily
**Server**: nginx
**Date**: Wed, 30 Nov 2022 10:15:43 GMT
**Content-Type**: text/html
**Content-Length**: 138
**Connection**: close
**Location**: https://IP:5656/
**X-Frame-Options**: SAMEORIGIN
**X-Content-Type-Options**: nosniff
**X-XSS-Protection**: 1; mode=block
It probally redirects to ip:port/login/
That should be fine …
Even running curl -I IP:5656/login
shows a 302 Moved Temporarily
response…
What does it mean?
I really need to solve this issue, as this is a production server, and the idea to have to reinstall it from scratch is really the last thing I would like to do…
Try IP:5656/login/ instead…
Already tried… see my comment above!
Found the culprit… Cloudflare… Hestia panel was proxied through CF… WTF…
Don’t remember I did set this in the past, I usually don’t use it for Hestia panel but only on Website…
Thanks a lot anyway!
This is one of many reasons why I do not like or use Cloudflare. In the past, they caused me nothing but trouble. With Hestia, I do not think Cloudflare is needed.
