Hi, today I cannot log into my control panel.
I checked with SSH, my sever is accessible.
Also, the port 8083 is enabled, of no problem.
Check that Hestia service is running:
systemctl status hestia
Check that it is listening on the right port:
lsof -Pn +c0 -i:8083 -sTCP:LISTEN
Also check that your client ip has not been banned to connect over port 8083:
v-list-firewall-ban
For the second command, it seems to be of no problem.
For the third command, it returned “command not found”.
Hestia package is not installed …
Thanks!
What shall I do?
ls /usr/local/hesita/
Then there is no Hesita installed on that server …
I don’t think we can’t do a lot…
