dear sir,
i cant acces to login phpmyadmin… how i can acces this ? this is new server with new setting on hestia cp
Basically you should use yourDomain/phpmyadmin instead of yourServerIp/phpmyadmin
Take a look to these docs:
Why I can’t use http://ip/phpmyadmin/
Database & phpMyAdmin SSO | Hestia Control Panel
How can I enable access to http://ip/phpmyadmin/
thks for answer… i want to try it
i still confused to follow this …
i am still failed, and cannt acces phpmyadmin
after i write this >>> nano /etc/apache2/conf.d/ip.conf
and then appear like this
have to i save directly using control x, and then save … ???
i ask about writing include optional … ???
Hi @erwin,
Note: As I don’t know which is your ip, I will use 203.0.113.1 in all my post so you must replace it with your own public ip.
Note 2: all the commands must be executed as user root.
/etc/apache2/conf.d/ip.conf doesn’t mean literally the file ip.conf but a file with your public ip like 203.0.113.1.conf
To view the files inside that dir:
ls -l /etc/apache2/conf.d/
Once you know what is the actual conf file, edit it:
nano /etc/apache2/conf.d/203.0.113.1.conf
And this is what you would see before modifying it:
Listen 203.0.113.1:8443
Listen 203.0.113.1:8080
<VirtualHost 203.0.113.1:8080>
ServerName 203.0.113.1
DocumentRoot /var/www/html/
Alias /error/ /var/www/document_errors/
</VirtualHost>
<VirtualHost 203.0.113.1:8443>
SSLEngine on
SSLVerifyClient none
SSLCertificateFile /usr/local/hestia/ssl/certificate.crt
SSLCertificateKeyFile /usr/local/hestia/ssl/certificate.key
</VirtualHost>
Now you need to add IncludeOptional /etc/apache2/conf.d/*.inc inside both VirtualHost blocks and it should look like this:
</VirtualHost>
SSLEngine on
</VirtualHost>
Save the file.
Remove the ip.conf file you created previously:
rm -f /etc/apache2/conf.d/ip.conf
And now restart Apache2:
systemctl restart apache2
chown -R root:www-data /etc/phpmyadmin/
