Can't attach kibana on localhost:5601
I tried to modify my.stpl like this:
server {
	listen      %ip%:%web_ssl_port% ssl;
	root        %sdocroot%;
	ssl_stapling        on;
	ssl_stapling_verify on;
	# TLS 1.3 0-RTT anti-replay
		deny all;
		return 404;
	location /app/ {
		proxy_pass http://localhost:5601/app/;
		location ~* ^.+\.(%proxy_extentions%)$ {
			root           %docroot%;
			access_log     /var/log/%web_system%/domains/%domain%.log combined;
			access_log     /var/log/%web_system%/domains/%domain%.bytes bytes;
			expires        max;
			try_files      $uri @fallback;
	location / {
		location ~* ^.+\.(jpeg|jpg|png|webp|gif|bmp|ico|svg|css|js)$ {
			expires max;
		location ~ [^/]\.php(/|$) {
			try_files $uri =404;
			fastcgi_index index.php;
			fastcgi_pass %backend_lsnr%;
	location /api/ {
		proxy_pass http://localhost:1025/;
			root           %docroot%;
			expires        max;
	location /error/ {
	location /vstats/ {
	proxy_hide_header Upgrade;
My back-end on localhost:1025 is working well.
But I don’t know how to connect to kibana on localhost:5601?
Try: proxy_pass http://localhost:5601;
I did : proxy_pass http://localhost:5601;
When I access ‘mydomain/app’, I experience the following:
This page isn’t working
mydomain redirected you too many times.
ERR_TOO_MANY_REDIRECTS
