I want to control mysql database remotely
i have allowed port 3306
as in the picture
But also I can’t control data base remotely
can you help me?
as in the picture
can you help me?
I have followed the steps but it refuses to connect
Error SQLSTATE[HY000] [2002] No connection could be made because the target machine actively refused it
Fatal error: Uncaught mysqli_sql_exception: No connection could be made because the target machine actively refused it in C:\xampp\htdocs\tecwindow\2.php:7 Stack trace: #0
Check the mysql configuration (specifically the ip bind)
The problem has been caused by Hestia Control Panel
function of opening port inside firewall of Hestia Control Panel did not work as expected
For this, I opened port with this command inside ssh
iptables -A INPUT -p tcp --dport 3306 -j ACCEPT
