I’ve tried doing flask, I’ve set up a service file to make sure its always online, however when I make the proxy template in nginx it says the proxy template cannot be found even though its there. So I’m not sure what to do.
What is the template name and where are you saving it?
template name, flask.tpl. Saving it at /usr/local/hestia/data/templates/web/nginx/
You must create flask.stpl
too.
What do I put in the stpl file? Same thing from the tpl?
Did you copy flask.tpl
from another template? Then copy the source stpl template to flask.stpl
and do the same modifications you did to flask.tpl
No, I made the template:
server {
listen %ip%:%proxy_port%;
error_log /var/log/%web_system%/domains/%domain%.error.log error;
deny all;
return 404;
location / {
proxy_pass http://%ip%:5000;
proxy_set_header Host $host;
location /error/ {
Use this as flask.stpl
server {
listen %ip%:%proxy_ssl_port% ssl;
ssl_certificate %ssl_pem%;
ssl_stapling on;
ssl_stapling_verify on;
# TLS 1.3 0-RTT anti-replay
deny all;
return 404;
location / {
location /error/ {
Awesome, that worked. Thank you, sahsanu!
