Hi, wehen i try install this panel i get lot of errors
Updating currently installed packages, please wait… W: Failed to fetch http://ppa.launchpad.net/ondrej/apache2/ubuntu/dists/jammy/InRelease 503 Service Unavailable [IP: 185.125.190.80 80]
E: Unable to locate package php8.2
E: Couldn’t find any package by glob ‘php8.2’
E: Couldn’t find any package by regex ‘php8.2’
E: Unable to locate package php8.2-apcu
E: Couldn’t find any package by glob ‘php8.2-apcu’
E: Couldn’t find any package by regex ‘php8.2-apcu’
E: Unable to locate package php8.2-bz2
E: Couldn’t find any package by glob ‘php8.2-bz2’
E: Couldn’t find any package by regex ‘php8.2-bz2’
E: Unable to locate package php8.2-cli
E: Couldn’t find any package by glob ‘php8.2-cli’
E: Couldn’t find any package by regex ‘php8.2-cli’
E: Unable to locate package php8.2-common
E: Couldn’t find any package by glob ‘php8.2-common’
E: Couldn’t find any package by regex ‘php8.2-common’
E: Unable to locate package php8.2-curl
E: Couldn’t find any package by glob ‘php8.2-curl’
E: Couldn’t find any package by regex ‘php8.2-curl’
E: Unable to locate package php8.2-gd
E: Couldn’t find any package by glob ‘php8.2-gd’
E: Couldn’t find any package by regex ‘php8.2-gd’
E: Unable to locate package php8.2-imagick
E: Couldn’t find any package by glob ‘php8.2-imagick’
E: Couldn’t find any package by regex ‘php8.2-imagick’
E: Unable to locate package php8.2-imap
E: Couldn’t find any package by glob ‘php8.2-imap’
E: Couldn’t find any package by regex ‘php8.2-imap’
E: Unable to locate package php8.2-intl
E: Couldn’t find any package by glob ‘php8.2-intl’
E: Couldn’t find any package by regex ‘php8.2-intl’
E: Unable to locate package php8.2-ldap
E: Couldn’t find any package by glob ‘php8.2-ldap’
E: Couldn’t find any package by regex ‘php8.2-ldap’
E: Unable to locate package php8.2-mbstring
E: Couldn’t find any package by glob ‘php8.2-mbstring’
E: Couldn’t find any package by regex ‘php8.2-mbstring’
E: Unable to locate package php8.2-mysql
E: Couldn’t find any package by glob ‘php8.2-mysql’
E: Couldn’t find any package by regex ‘php8.2-mysql’
E: Unable to locate package php8.2-opcache
E: Couldn’t find any package by glob ‘php8.2-opcache’
E: Couldn’t find any package by regex ‘php8.2-opcache’
E: Unable to locate package php8.2-pspell
E: Couldn’t find any package by glob ‘php8.2-pspell’
E: Couldn’t find any package by regex ‘php8.2-pspell’
E: Unable to locate package php8.2-readline
E: Couldn’t find any package by glob ‘php8.2-readline’
E: Couldn’t find any package by regex ‘php8.2-readline’
E: Unable to locate package php8.2-xml
E: Couldn’t find any package by glob ‘php8.2-xml’
E: Couldn’t find any package by regex ‘php8.2-xml’
E: Unable to locate package php8.2-zip
E: Couldn’t find any package by glob ‘php8.2-zip’
E: Couldn’t find any package by regex ‘php8.2-zip’
E: Unable to locate package php8.2-bcmath
E: Couldn’t find any package by glob ‘php8.2-bcmath’
E: Couldn’t find any package by regex ‘php8.2-bcmath’
E: Unable to locate package php8.2-fpm
E: Couldn’t find any package by glob ‘php8.2-fpm’
E: Couldn’t find any package by regex ‘php8.2-fpm’
E: Unable to locate package php8.2-soap
E: Couldn’t find any package by glob ‘php8.2-soap’
E: Couldn’t find any package by regex ‘php8.2-soap’
cp: cannot stat ‘/usr/local/hestia/install/deb/logrotate/httpd-prerotate/': No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/deb/sudo/admin’: No such file or directory
chmod: cannot access ‘/etc/sudoers.d/admin’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/deb/logrotate/hestia’: No such file or directory
ln: failed to create symbolic link ‘/usr/local/hestia/log’: No such file or directory
touch: cannot touch ‘/usr/local/hestia/log/system.log’: No such file or directory
touch: cannot touch ‘/usr/local/hestia/log/nginx-error.log’: No such file or directory
touch: cannot touch ‘/usr/local/hestia/log/auth.log’: No such file or directory
touch: cannot touch ‘/usr/local/hestia/log/backup.log’: No such file or directory
chmod: cannot access ‘/usr/local/hestia/log’: No such file or directory
chmod: cannot access '/var/log/hestia/’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/packages’: No such file or directory
sed: can’t read /usr/local/hestia/data/packages/.pkg: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/deb/templates’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/templates/web/’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/templates/dns/’: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/templates/web/unassigned/index.html’: No such file or directory
cp: cannot stat '/usr/local/hestia/install/common/templates/web/skel/document_errors/‘: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/firewall’: No such file or directory
sed: can’t read /usr/local/hestia/data/firewall/rules.conf: No such file or directory
cp: cannot stat ‘/usr/local/hestia/install/common/api’: No such file or directory
[ * ] Configuring OpenSSL to improve TLS performance…
hst-install-ubuntu.sh: line 1356: /usr/local/hestia/bin/v-generate-ssl-cert: No such file or directory
sed: -e expression #1, char 3: unexpected ,' sed: -e expression #1, char 1: unknown command:
[ * ] Enabling SFTP jail…
Error: can’t enable sftp jail
is offline. Nothing we can do about …
okey that mean just waiting
