Can't login to admin from first install. .
Good day to you all.
I’m failing at getting this software working properly. I have installed it twice per the instructions. The first time I used a unique username for the admin user and password set via installer command line. The second time I just used the installer without the command line and entered it all interactively. No errors, nothing complains.
Go the web to login and everything looks fine until I enter my credentials and it fails with “invalid username or password.”
Fresh Ubuntu 24.04 images each time. I noticed that there is sometimes a permissions issue that causes this and I tried my best to fix it, but only managed to make Hestia non-functional in the process.
So I’ve reinstalled again. Same issue. My data and sessions folders look like this:
root@nope:/usr/local/hestia/data# ls -al
total 44
drwxr-xr-x 11 root      root      4096 Mar 26 19:38 .
drwxr-xr-x 11 root      root      4096 Mar 26 19:37 ..
drwxr-xr-x  2 root      root      4096 Mar 26 19:37 api
drwxr-x---  2 root      root      4096 Mar 26 19:38 extensions
drwxr-xr-x  3 root      root      4096 Mar 26 19:42 firewall
drwxr-x---  2 root      root      4096 Mar 26 19:38 ips
drwxr-xr-x  2 root      root      4096 Mar 26 19:37 packages
drwxr-x---  2 root      root      4096 Mar 26 19:40 queue
drwxrwx---  2 hestiaweb hestiaweb 4096 Mar 26 19:40 sessions
drwxr-xr-x  5 root      root      4096 Mar 26 19:37 templates
drwxr-x---  3 root      root      4096 Mar 26 19:37 users
root@nope:/usr/local/hestia/data# cd sessions
root@nope:/usr/local/hestia/data/sessions# ls -al
total 12
drwxrwx---  2 hestiaweb hestiaweb 4096 Mar 26 19:40 .
drwxr-xr-x 11 root      root      4096 Mar 26 19:38 ..
-rw-------  1 hestiaweb hestiaweb 2619 Mar 26 19:40 sess_9mhs5r8h9s7smv0ssrjqelmcce
Anything I might try?
Thanks!
Brandon
Well, I answered my own question. But rather than pulling my question down I’m going to try to help the next person who searches.
The issue is that I don’t yet have an SSL certificate installed, so I needed to use my IP instead of the FQDN. It worked fine with just the IP. This might be worth having the login logic detect and provide feedback in the UI, I don’t know. Anyway. Carry on.
