I am trying to restore my backup over ftp with local backups turned off.
When restoring, I am getting can’t unpack PAM container. Manually everything works, as well as tar -R --ignore-failed-read --ignore-command-error --ignore-zeros -xvf
But isn’t it supposed to be working over ftp as well?
Certainly, so I have only FTP backups set up, without local ones.
What I have done exactly is opened the backup window, chose the last backup and clicked on restore all (separately it doesn’t work as well). So after a short while, I am getting the mentioned error. For some reason Hestia can’t extract the files by itself. I thought there might be an issue with the archive, but manually I am able to restore it. Not sure what might be the problem
I would suggest to manualy download the backup to /backup, then restore it from there using the v-restore-user command - it will give you much more output and details.
Thank you for checking. I can clearly see that the backup file is downloaded, just not to the correct user. It downloads to the admin account instead of the user one
