Can't unpack site.com data tarball
After updating to version v1.8.4, when restoring a backup, I get: Can’t unpack site.com data tarball
As far as I understand, the backup is still being restored. The data changes most likely correctly. But such an error message occurs. I tried both types of compression, but the result is the same.
If the data changes, then the archive is still being unpacked. Completely or not, it is not clear.
I don’t know if this is just my problem or if it’s global.
We run the restore test on a daily basis and we don’t see any issues with it …
Thanks for the answer. Maybe my update went wrong. But I have 1 more server, I will test it on it.
Check the permissions of the backup folder is should root:root with 755 permissions
Folder permissions are correct. I haven’t touched them since the server was installed. Backups are formed in the folder correctly and there are no problems with their creation. There is a problem only with restoration through a backup.
You should try to unpack it manually to see what the actual error is:
mkdir /tmp/testunpack
tar xf /backup/HERETHENAMEOFTHEBACKUP -C "/tmp/testunpack" --no-wildcards "./hestia"
Understood, thanks, I will try and write.
Did you manage to solve the problem? I have the same problem for several days without doing anything on the system?
– WEB –
2023-10-20 21:11:43 mysite.info
tar: files_backups: Cannot utime: Operation not permitted
tar: Exiting with failure status due to previous errors
Error: Can’t unpack mysite.info data tarball
Hi all,
Just saw this topic while I had a same problem last night. I did a verbose run of restore procedure, In my case the problem was some of the files and folders inside the public_html folder which I created manually had a wrong ownership ( root:root instead of hestia_user:hestia_user ) so during the restore hestia_user was unable to recreate them. So before disaster happens go and check all your permissions on your public_html files and folders. I hope this help people in the future.
