Can't upgrade from MariaDB 10.11 to MariaDB 11.4 on HestiaCP
Hey,
I have installed fresh Debian 12.7 (x86_64) with HestiaCP and tried this multiple times, but it always fails no matter what. I also tried other version such as 11.5, but they fail as well. Notice that I don’t add any websites or databases before this process. The installation is fresh and nothing is modified.
Steps to reproduce:
  1. apt update & apt upgrade
  2. What is installed: PHP-FPM, iptables, HestiaAPI, VSFTPD, MariaDB, Fail2Ban, Intreactive install, Hostname
  3. Run HestiaCP (v1.8.12) installation and reboot the server after successful installation
  4. nano /usr/local/hestia/install/upgrade/manual/upgrade_mariadb.sh (modify target ver to 11.4)
  5. bash /usr/local/hestia/install/upgrade/manual/upgrade_mariadb.sh
  6. Here is full output and errors PrivateBin
Tried to remove unknown variables from the error logs, but it did not help. Any suggestions what I did wrong? Thank you!
You can modify the install script and set the wanted mariadb version directly.
Install the plugins:
apt install mariadb-plugin-provider-bzip2 mariadb-plugin-provider-lz4 mariadb-plugin-provider-lzma mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy
I tried to do this, but it still installed 10.11.6-MariaDB-0+deb12u1 Debian 12 after running mariadb -v or mysql -v.
Steps to reproduce:
  1. Get Debian installation config, instead of default one
    wget https://raw.githubusercontent.com/hestiacp/hestiacp/release/install/hst-install-debian.sh
  2. Modify DB_VERSION=‘10.6’ to DB_VERSION=‘11.4’ and save changes.
    nano hst-install-debian.sh
  3. Run the modified installer
    bash hst-install-debian.sh
Not sure what I did incorrectly, but it seems like it refused to install newer version. No errors or warning there show during installation.
Unfortunately this didn’t work either. Here is full output and I am still getting same errors.
I think Hestia 1.8.x is still using Debian MariaDB from “Debian” package server
So in that case the the main branch and and copy the part where it install mariadb repo
As @eris pointed out, when using Debian 12, Hestia installer doesn’t use the MariaDB repo, uses Debian repo.
Edit hst-install-debian.sh and on line 748 remove the comment on #deb:
From this:
 echo "#deb [arch=$ARCH signed-by=/usr/share/keyrings/mariadb-keyring.gpg] https://dlm.mariadb.com/repo/mariadb-server/$mariadb_v/repo/$VERSION $codename main" > $apt/mariadb.list
to this:
 echo "deb [arch=$ARCH signed-by=/usr/share/keyrings/mariadb-keyring.gpg] https://dlm.mariadb.com/repo/mariadb-server/$mariadb_v/repo/$VERSION $codename main" > $apt/mariadb.list
Thank you for clarification, since I didn’t understand exactly that eris said :smiley:
I just tried it once again and it worked. The only warning during installation was:
[ * ] Configuring MariaDB database server...
/usr/bin/mysql_install_db: Deprecated program name. It will be removed in a future release, use 'mariadb-install-db' instead
Once again thanks everyone in this thread. Really like the community! :love_letter:
Yeah for now it is fine …
