$cfg['TempDir'] (/usr/share/phpmyadmin/tmp/) is not accessible
All,
Received the following warning after logging in the built-in phpMyAdmin for “any” DB running in my instance of HestiaCP:
The $cfg['TempDir'] (/usr/share/phpmyadmin/tmp/) is not accessible. phpMyAdmin is not able to cache templates and will be slow because of this.
Example below:
This is how the /usr/share/phpmyadmin directory looks like:
Note:
Any help is much appreciated.
Thanks in advance.
Hi @ivano.buffa,
It’s a bug. Execute this command to fix it:
chown -R hestiamail:www-data /usr/share/phpmyadmin/tmp/
Thanks for your swift reply. I applied the suggested modification. Currently monitoring… I will mark your answer a as solution shortly!
My regards sir
