hi
Is there a way to change the default index.html? Is it generated or copied from somewhere?
Can i make one new one and replace a template?
The original one are ok, but i want to make a custom one with info relative to my setup.
Hi again ![]()
The default index.html is here:
/usr/local/hestia/data/templates/web/skel/public_html
If you modify it and you don’t want that it will be updated on next Hestia update, then change POLICY_SYNC_SKELETON to no.
v-change-sys-config-value POLICY_SYNC_SKELETON no
Thaks again <3
