The problem is that after each CP update or rebuild the settings in
/home/user/conf/web/domain.com/apache2.ssl.conf
change back to the default which are set in
/usr/local/hestia/data/templates/web/apache2/php-fpm/hosting.stpl
I can edit the above template, but as i understand it this is also over written on update/rebuild.
As i understand it i can copy the above template to a new template which will not be updated on update/rebuild, though if there are any changes to the default template on update i will need to transfer these to the copied template.
Is there a way to set default php values with the need to copy default to new template and not have edits over written on update/rebuild?
I should not need to, if they are set in /etc/php/version/fpm/ph.ini then they should be reflected in
/home/user/conf/web/domain.com/apache2.ssl.conf !!
Changes made in php.ini will not update any preset values in Apache2.ssl.conf for that domain
Just remove those preset values from you template and it should work fine. Or use as explained .user.ini or .htaccess (Probally not work because default is fpm)
