Change Hestia Nginx web port
Where can I change Hestia nginx web port from default 80 and 443 to something else?
I tried to change in nano /usr/local/hestia/conf/hestia.conf, but it doesn’t work.
I have also updated the firewalls rule in Hestia.
change here : /etc/nginx/sites-available/default
then systemctl restart nginx.service
then test result : netstat -tlpn| grep nginx
Please read more about how nginx work before change also backup etc.
I wish someone expert too confirm this solution , if it’s test environment then please let me know the result
Changing nginx ports isnt supported. A lot of functions, for example lets encrytp, will stop working. Why do you want to change them anyway?
I want to change port to something else as I want to use port 80 for another nginx proxy manager to use it
Hestia will work fine for a proxy manager as long you create a few custom templates…
only lets encrypt not work if change nginx port 80,443 to other like 8080,4443?
You need to add all websites to proxy manager as well.
Letsencyrpt will break and maybe other functions. But also don’t come to use for support if something breaks.
Hestia runs the same Nginx as proxy manager does and can do everything that proxy manager does so there is no reason to use it instead,…
